It is currently Wed Apr 01, 2015 3:36 am
 Post subject: XP/Win7 Network
PostPosted: Mon Apr 12, 2010 4:26 am
I currently have a Windows 7 desktop and a XP laptop on the same home network. They share files/printer/ect with no problem.
I decided to get around to actually fixing my kids computer and had to reinstall the OS which is XP.
This computer is a desktop with a wireless card sitting 10 feet from my router, so it gets a good signal. But, I can't get it to connect to my network. It connects fine to the internet, but when I try to setup a network on it, it will not change the network name to the correct one. It still calls it "Windows Network" and won't change it.
Any ideas what could be causing this? I've never had this problem with the XP laptop before.
PostPosted: Mon Apr 12, 2010 12:49 pm
Are they in the same workgroup? The system properties should give you the name.
PostPosted: Mon Apr 12, 2010 6:56 pm
Yes they are.
PostPosted: Mon Apr 12, 2010 8:05 pm
Million Club [PC]*
Million Club [PC]*
Before I try to troubleshoot it any farther, I'd try a simple TCP/IP reset.
Open a command prompt, and type the folowing: netshp int ip reset C:\resetlog.txt
and reboot the box. Try to change the workgroup name again. Work yes/no?
If no, open a command prompt on the problem machine, as well as a working box, and type ipconfig /all
Post the output here, indicating which is which.
(to post a command prompt: right-click anywhere in the window > select all > <Enter>. Contents are now copied to the Clipboard; simply paste into your reply.)
RW, your OP reads that the workgroup name isn't correct ("I can't change it" is what you wrote); however, your reply to Airheadq says otherwise ("they're the same".) Can't be both......
PostPosted: Tue Apr 13, 2010 3:28 am
Thats the odd thing, when I look at the workgroup name, it shows the correct name. But when I tried to add a printer, it shows a different name when I browse for a network printer....
PostPosted: Tue Apr 13, 2010 3:52 am
From the Windows 7 desktop:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Kevin-Desktop
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 00-26-18-FE-7B-0D
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::f9c0:5e99:89b1:b43e%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.103(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Monday, April 12, 2010 7:36:29 AM
   Lease Expires . . . . . . . . . . : Wednesday, April 14, 2010 7:36:29 AM
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 234890776
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-C4-7E-E3-00-26-18-FE-7B-0D
   DNS Servers . . . . . . . . . . . : 205.152.37.23
                                       205.152.150.23
   NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{9446B63D-1715-498B-91A7-151C254A04DF}:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 9:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e74:2c1a:2d4:3f57:fe98(Prefe
rred)
   Link-local IPv6 Address . . . . . : fe80::2c1a:2d4:3f57:fe98%13(Preferred)
   Default Gateway . . . . . . . . . : ::
   NetBIOS over Tcpip. . . . . . . . : Disabled
PostPosted: Tue Apr 13, 2010 3:54 am
From the problem machine:
        Host Name . . . . . . . . . . . . : kids
        Node Type . . . . . . . . . . . . : Unknown
        Description . . . . . . . . . . . : VIA Rhine II Fast Ethernet Adapter
        Physical Address. . . . . . . . . : 00-13-D4-08-4F-27
Ethernet adapter Wireless Network Connection:
        Description . . . . . . . . . . . : ASUS 802.11g Network Adapter
        Physical Address. . . . . . . . . : 00-22-15-7C-57-2D
        Dhcp Enabled. . . . . . . . . . . : Yes
        IP Address. . . . . . . . . . . . : 192.168.1.107
                                            205.152.150.23
        Lease Obtained. . . . . . . . . . : Tuesday, April 13, 2010 7:29:45 AM
        Lease Expires . . . . . . . . . . : Wednesday, April 14, 2010 7:29:45 AM
PostPosted: Fri May 07, 2010 7:22 pm
Million Club [PC]*
Million Club [PC]*
I'm sorry - been crazy-busy with about a million things lately. Haven't had the time to post in a while.
Did you try doing a TCP/IP reset on the kid's PC yet?
A couple of potential issues that I see (from your ipconfig output):
1- WINS looks to be disabled. Enabling it on each machine can help with local name-resolution issues. This article will show how to enable WINS.
2- DNS. Generally, it's preferable for your router to act as a DNS Forwarder (they have this feature for a reason), rather than each workstation doing DNS lookups directly. Your config can, again, create local name-resolution issues.
Try entering your chosen DNS server addresses into your router config, and change the DHCP options on it to point the clients to the router (rather than directly to BellSouth) for DNS lookups.
