It is currently Mon Jun 17, 2013 10:59 pm
 Post subject: Help! Can't find FreeeNas on my network without wireless.
PostPosted: Tue Apr 06, 2010 5:08 pm
I built the FreeNas box from the January 2010 issue. Everything worked great until I tried plugging my PC into the router instead of going wireless. Now my PC doesn't see the FreeNas on the network. When I go wireless it's there but when I plug the PC into the Linksys router (and disable the wireless) I don't see it.
The connections are good. I checked that. On step 7 of the article (p51) on the part of the instructions called: "Set Lan IP Address" There is a sentence I did not understand and I think this might be my problem. It states "You'll need to go into your router's config and reserve the IP you chose."
What do I need to do in my router's config? Is this the problem?
(The reason I'm doing this is to gain speed. It's too slow over the wireless)
Thanks!
Jeff
PostPosted: Wed Apr 07, 2010 9:19 am
In order to help you with your problem, it would be helpful for us to know the make and model of the router you are using.
