It is currently Fri Apr 17, 2015 7:43 pm
 Post subject: Router Password?
PostPosted: Tue Mar 30, 2010 9:21 pm
Quick question. how can i go about changing the password for the router?
and also is there a way to kinda monitor who/whats connecting to your router?
PostPosted: Wed Mar 31, 2010 12:08 am
Chief Surgeon
Chief Surgeon
We need to know ('cause we're not mind readers)...
1.) Make, Model, and revision of Router.
2.) What do you normally connect to it (List of computers, laptops, smartphones, game consoles, etc).
PostPosted: Fri Apr 02, 2010 6:52 pm
well i ment for really any router but its a Linsys WRT54GL and its connected to my PC and every so often my girlfriends laptop and my laptop. thats about it
PostPosted: Fri Apr 02, 2010 7:04 pm
typically you can just hit the web interface via it's lan address. That address though varies from router to router, so this is time to crack that manual.
If you're using a linksys, I'm going to guess it'll be 192.168.1.1
