It is currently Sun Feb 01, 2015 4:32 pm
 Post subject: what switch should i use for 25m speed
PostPosted: Thu Mar 25, 2010 10:50 am
the guy that installed my internet said that older switches wouldnt be able to withstand the speeds that the modem would pump out. I just want to make sure I will get one that is fast enough to support my internet lol. I am also looking to buy it at best buy as i have a gift card there, would you be able to recommend which one will work fine? http://www.bestbuy.ca/Search/SearchResu ... gory=26015
PostPosted: Thu Mar 25, 2010 11:26 am
As long as your router/switch supports 100mbps (most are 10/100mbps), you're fine. Nobody has been making 10mbps devices for many years now, so unless you're literally digging through some old parts bins at work, it shouldn't be a concern.
Btw, realize you will need a ROUTER and not just a SWITCH if you want to share that Internet connection w/ other PCs and network devices.
PostPosted: Thu Mar 25, 2010 4:25 pm
Monkey Fed [PC]
Monkey Fed [PC]
Not necessarily. Most internet modems come with built in router and DHCP capabilities, even if they only have one port in the back. I've got an 8 port switch right behind my modem and it works just fine.
To the OP, can you post the make and model of your internet modem so we can see if a switch will work for sure?
PostPosted: Thu Mar 25, 2010 5:05 pm
I'm not sure I'd agree *most* modems come w/ integrated routers. You tend to see such integration w/ DSL, much less w/ cable. I don't know which has the greater install base.
I stand by what I said, he needs a router. I never said it had to be purchased separately or couldn't be integrated into a single unit along w/ the modem. My concern was two-fold. The only device ever specifically mentioned was a switch. Plus the OP mentioned the need to support 25mbps (something I don't think any DSL service is capable of providing, most top out at ~3mbps, but I do see Version has a 7mbps plan in select areas).
All that says to me is, it’s very likely the OP has cable and will need a separate router. I just didn’t want him getting a switch by mistake and thinking he could share the Internet. But of course, in the off chance it’s an integrated cable modem+router, the addition of a switch is fine.
PostPosted: Thu Mar 25, 2010 5:23 pm
Monkey Fed [PC]
Monkey Fed [PC]
Qwest and Verizon both have 20 MB+ DSL speeds. Also, the OP never mentioned what speed his internet runs at, nor the need to run 25 mb/s or faster. Only that he was told older switches couldn't keep up. That means 10 mb speeds or faster. Why buy a 50-60 dollar router when a 20-30 dollar switch will work just fine? Besides, it's the OP's choice anyway.
PostPosted: Thu Mar 25, 2010 5:50 pm
Check the OP's title.
 Post subject: Re: what switch should i use for 25m speed
PostPosted: Thu Mar 25, 2010 7:29 pm
Anything labeled with either Gigabit/1000BaseT/1000Mbps will suit your needs. Understand that the switch will negotiate to slower speeds if need be.
Personally, I think your tech has Rocks in his head. I haven't seen a straight 10BaseT switch on the shelf for close to 10 years and you can't say a switch might not handle it, if you network card can only handle 10BaseT :)
PostPosted: Fri Mar 26, 2010 7:48 am
Hired Gun
Hired Gun
These days integrated routers/modems are more common then not, even with cable. However it's all just assumptions on our part until the OP comes back to clarify. Either way I personally would rather have an independent router. You can always disable the routing capabilities on the modem. Most of them suck and have limited customizable features.
