It is currently Sun Apr 26, 2015 3:36 am
 Post subject: WRT54GX4 won't save settings, resets or something.
PostPosted: Tue Mar 16, 2010 2:27 pm
For some reason in the last few days my Linksys WRT54GX4 router won't keep settings. It keeps resetting or something. It will keep security settings for maybe 12 hours and then will go back to unecrypted with no network name. I looked in Event Viewer and I keep seeing an error pop up that says DHCP and it says this:
Quote:
The IP address lease 192.168.1.100 for the Network Card with network address 00044B008CD2 has been denied by the DHCP server 192.168.1.1 (The DHCP Server sent a DHCPNACK message).
I have no idea if this is related or what it means in English. I've tried holding the reset for 30 secs and power cycling the router with no results.
PostPosted: Tue Mar 16, 2010 9:03 pm
Do you have the latest firmware revision installed on this router?
PostPosted: Wed Mar 17, 2010 2:38 pm
Yes.
PostPosted: Thu Mar 18, 2010 3:52 am
Hired Gun
Hired Gun
How about the most current drivers for you network card in your computer?
PostPosted: Thu Mar 18, 2010 6:10 am
Are you using WPA, changed the default administrative password and disabled the ability to login and administer the router from a wireless connection?
If everything was working fine up until recently I wouldn't rule out a "guest" on your network. Especially if you're using the default or an otherwise weak password.
PostPosted: Thu Mar 18, 2010 6:26 pm
I have the latest firmware and drivers. I have WPA and the remote admin has been disabled since I got the router. I've released and renewed the IP address as well. I tried uninstalling the NIC today so I'll see if that does anything. The settings seem to stay overnight and the next day the router is reset. I'm thinking the router might just be crapping out.
