It is currently Tue May 05, 2015 10:28 am
 Post subject: D-Link DSS-5+
PostPosted: Mon Jan 24, 2005 6:41 pm
I have the switch found below. I was hoping I could play Xbox Live! and also be on the computer. I got this switch for free, so I don't really know what I can do with it. Can I share files between a computer? Will the Xbox thing work? What about games? Any help would be appreciated.
http://www.newegg.com/app/ViewProductDe ... 009&depa=0
PostPosted: Tue Jan 25, 2005 9:44 am
You are going to need to do 1 of 2 things to use XBL and your computer at the same time. Either buy a 2nd IP address from your broadband provider or buy a router. Both solutions will allow you to have multiple devices online at the same time. Routers are very cheap now and I would suggest that method. That switch doesn't really help you in it's current state.
