It is currently Sat Jan 24, 2015 9:04 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 12, 2010 11:31 am
cjenks wrote:
any1 ????? should i buy a new router?
You do NOT need a new router.
All you have to do is use your router's administrative interface and update the DNS server addresses. By default it will usually specify its own address as the DNS server and RELAY and requests from clients over to the DNS server(s) specified by the ISP. You can usually override that behavior by added DNS server addresses of your own. It's just a matter of finding that location in the router's administrative interface. It’s usually in the same location where you specify how to connection to the ISP (e.g., DHCP, PPPoE), assign it an IP address of its own, name the router, etc. It may say something like “Static DNS #1â€
PostPosted: Fri Mar 12, 2010 11:35 am
all the above dont make no sence to me lol is there anyway you can explain step by step on what to do.
PostPosted: Fri Mar 12, 2010 11:36 am
What's the make and model of your router?
PostPosted: Fri Mar 12, 2010 12:30 pm
netgear dgb111g
PostPosted: Fri Mar 12, 2010 12:56 pm
1. Login to your router at http://192.168.0.1 (unless you changed the defaults, user = admin, password = password)
2. Go to Basic Settings, locate “Domain Name Server (DNS) Addressâ€
PostPosted: Fri Mar 12, 2010 1:39 pm
i already done all this and it didnt work :roll:
PostPosted: Fri Mar 12, 2010 2:30 pm
i just done a ping test again and here is the resluts
for some reason sometimes the connection is fast then it will slow down again cant figue out why tho?
PostPosted: Fri Mar 12, 2010 2:35 pm
Monkey Fed [PC]
Monkey Fed [PC]
I JUST noticed something. That netgear you posted? net gear WG111v2? That's the USB adapter that plugs into your notebook/PC. That's not a router, bro. What router/modem do you have?
Also, you have the latest software for that usb adapter? It can be found here: http://kb.netgear.com/app/answers/detail/a_id/713
Also, I'd suggest flashing the firmware of your modem/router, but without knowing what it is, I can't give any recommendations on that.
PostPosted: Fri Mar 12, 2010 2:42 pm
i have a netgear DGB111G
and i do not use the USB stick that came with it
ill try updating now
PostPosted: Fri Mar 12, 2010 2:56 pm
Monkey Fed [PC]
Monkey Fed [PC]
Ok. That link I posted was for the USB stick that goes i the lappy or desktop. You'll need to hit netgears home site and find a firmware update for your router.
PostPosted: Fri Mar 12, 2010 2:57 pm
i cant find one mate can you help?
PostPosted: Fri Mar 12, 2010 3:21 pm
Monkey Fed [PC]
Monkey Fed [PC]
No wonder you couldn't find it. That number you gave me was for your whole package, not just the router itself. Your router model number is DG834Gv5. And, here is the support page for it.
http://kb.netgear.com/app/answers/detail/a_id/12760
PostPosted: Fri Mar 12, 2010 3:42 pm
when i try and upload the file i get the message " Invalid filename was provided, please enter again:(*.img)
PostPosted: Fri Mar 12, 2010 3:59 pm
I just updated ill let you know how it goes tomorrow please keep an eye on this thread. night :D
p.s. thanks for your help so far
PostPosted: Fri Mar 12, 2010 4:16 pm
just a quick update before i go to sleep:
still now working :( and now i keep getting server not found :?
dont know what else to do
PostPosted: Sat Mar 13, 2010 6:07 am
could it be something to do with my line quality?
