It is currently Sun Feb 01, 2015 3:39 pm
 Post subject: how to map network drive over the internet?
PostPosted: Thu Mar 04, 2010 4:20 pm
at home I have two computers that on one of them all
the data.pic.movie ....
on other PC I map network drive and all working fine.
now I want to mount a network drive from the DATA PC
over the internet.
need help with that.
I using a netgear DG834G ADSL modem router
I know I need to use VPN some how but have no clew
PostPosted: Thu Mar 04, 2010 6:10 pm
Is this so YOU have remote access back to it at home, make it available to others, both?
You need to explain what you're trying to do, trying to accomplish, in non-technical terms first, then we'll see what technology can best be applied. There may be several options, or some that don't apply at all. But it's really difficult to keep things down to a manageable discussion without being much more specific.
PostPosted: Thu Mar 04, 2010 8:05 pm
Once you're VPN'd in mapping a drive is no different then what you're used to.
Sounds like your question is more along the lines of how to setup a VPN.
PostPosted: Sun Mar 07, 2010 10:14 am
VPN (virtual privet network) sound right.
need help with this.
Again>>> I have program that using a spesific drive over the network.
I like to use the program from difrent location but still able to use
the same network drive
PostPosted: Sun Mar 07, 2010 12:27 pm
LogMeIn Hamachi
https://secure.logmein.com/US/products/hamachi2/
Install it on both the home and remote machines. It installs a virtual network adapter within the 5.x.x.x network. You then create a named network that both the home and remote machines can join. Whalla, like magic you're both connected over a secure connection and have access to any resources on either machine. Simple to install, simple to configure, simple to use. Doesn't even require port management, and no issues w/ the ISP possibly blocking inbound ports (a common problem for traditional VPNs), since it uses a rendezvous server and NAT traversal. And it’s all FREE.
PostPosted: Sun Mar 07, 2010 6:05 pm
So what have you tried up to now to try to VPN to your home PC?
PostPosted: Sun Mar 07, 2010 7:10 pm
Would not right clicking an empty space in "My Computer" and selecting "add network location" be out of reach here?
Not enough info. I think the other guys know what you're using, but us casual users don't.
PostPosted: Sun Mar 07, 2010 8:31 pm
heh...I really don't know what he's using or doing in connecting back this other PC. and was hoping for something more in a response, but no dice..
PostPosted: Mon Mar 08, 2010 2:05 pm
At my home PC that what I did "My Computer" and selecting "add network location"
I would like to do the same over the internet.
PostPosted: Mon Mar 08, 2010 2:06 pm
Hired Gun
Hired Gun
Great, now read above where it's explained how to setup a VPN.
