It is currently Fri Apr 24, 2015 11:07 pm
 Post subject: Suggestions b g network with a printer
PostPosted: Mon Mar 01, 2010 8:21 pm
Suggestions on a wireless b/g that can network a printer?
2 wired 1 xp, 1 vista
1 laptop win 7 home
1 printer= runs out of paper at the worst time
blood type O²
tanks in advance
I'm new
PostPosted: Mon Mar 01, 2010 9:43 pm
Hired Gun
Hired Gun
Wireless what, Router, WAP? Any wireless router can handle a printer provided the printer is equipped with wireless capabilities. Whats your price range?
PostPosted: Mon Mar 01, 2010 10:47 pm
it's a router I be wantin' I believe
PostPosted: Tue Mar 02, 2010 5:32 am
Chief Surgeon
Chief Surgeon
Yes, we need a bit more info...
Do you have a router already? Because unless you want the printer independent of any computer, you can just share it through the network - so long as that computer is on (provided the network is already setup and functioning properly).
What model printer? Some printers - primarily all-in-ones - don't like being shared. Most all-in-ones will only share print functions unless they were designed for networking.
You could also add a network print server to an existing network.
PostPosted: Tue Mar 02, 2010 11:12 am
Hired Gun
Hired Gun
The Dlink DIR-655 is one of the best Bang for Buck routers out there.
PostPosted: Tue Mar 02, 2010 5:15 pm
thanks for the help
I read a little more
picked one up
cheers
