It is currently Sat Apr 25, 2015 4:37 pm
 Post subject: Buffalo WHR-G54S with Tomato > Switch to DD-WRT? How Plea
PostPosted: Thu Feb 25, 2010 2:36 pm
Hello, I have a Buffalo WHR-G54S running the Tomato fireware (V1_27.7) and I would like to install DD-WRT on it. I have searched but I no clear answers were found.
Any help would be great!
Thanks a lot!
PostPosted: Thu Feb 25, 2010 3:53 pm
If you're asking how to move from tomato to dd-wrt directly, I'm not sure you can (maybe you can, but I didn't check). Usually there are instructions for moving back to the original firmware of the manufacturer. And at that point you can just install dd-wrt as normal.
Yeah, it’s a bit of a pain if you don’t really have to, put locating information about moving from tomato straight to dd-wrt always seems sketchy to me.
At least that's been the approach I've used in the past, just to be safe.
PostPosted: Sat Feb 27, 2010 1:03 am
Hired Gun
Hired Gun
Same here I always go back to the manufacturer firmware first. This reduce your chances of bricking your router.
PostPosted: Sat Feb 27, 2010 5:56 am
I can't find out how to return to the manufacturers firmware. Does anyone know how for this router...
Thanks
PostPosted: Thu Apr 01, 2010 6:11 pm
here is a screenshot showing where you go in the router admin to update your firmware...
http://i.imgur.com/bzsbo.png
you should go back to the original manufacture, then on to whatever it is you want running on there.
