It is currently Wed Jun 19, 2013 10:37 pm
 Post subject: Connecting my wireless rounter to my wired rounter problem
PostPosted: Sat Feb 20, 2010 5:01 pm
Hi,
I have a D-Link DI-604. I have 3 main comps and a spare comp. A network drive and a WII. All connected.
I previous setup was to have the 4th output of the router into a generic switch, which I connected the Netdrive, spare comp and wii to.
This let me connect the 3 main comps straight to the router.
Now I want to move the spare 4th comp upstairs, so I bought a D-Link Dir-601 to replace the switch with. It a super cheap wireless router so I still want to use my old router for the main computers.
I hooked the 601 to the 604 and have finally gotten the 4th compter using the wireless connection with encryption, but I can't seem to connect to the the network drive, which is on the second router.
I have upnp and dhcp disabled on the second router and assiged it a different ip address than the first router.
Sorry so long. Any ideas?
Rick
PostPosted: Sat Feb 20, 2010 5:38 pm
Make sure the DIR-601 is patched to the DI-604 LAN to LAN, not WAN to LAN.
[dir-604](lan)<--wire-->(lan)[dir-601]
PostPosted: Sat Feb 20, 2010 7:26 pm
Sorry,
but after shutting everything down and moving my wireless router to a better location I now have the netdrive showing up. I'll check uot the settings again if I have further problems.
Thanks.
Update, it seems I know why this was cheap, the signal strength is only about 30% right next to it and I don't get any thing upstairs but get 4 of my neighbors signals.
Looks like this is gonna be a write off and I'll buy a different one after all.
2nd update: it completely died. No power at all after only two days so it appears I got a lemon.
