It is currently Tue Mar 31, 2015 2:18 am
 Post subject: Slow Web Browser IE8 Firefox Chrome -- Please Help
PostPosted: Tue Feb 16, 2010 7:31 pm
I just finished my first custom build and I decided to install a wireless pci adapter to limit the number of cables that I would have to use.
Anyway, my signal strength is excellent and my rig is putting out 54 mbps. All of my downloads (when my browser is working) are super fast, yet when I start IE8, FireFox or Chrome, all of the browsers run incredibly slow. I'm not sure if it is a firewall issue or some other sort of connection problem, but any suggestions would be helpful. Thanks!
PostPosted: Tue Feb 16, 2010 9:17 pm
Visit SpeedTest.net and let's see what it reports. Let's get an objective reading on your browser performance.
PostPosted: Wed Feb 17, 2010 5:44 am
on my laptop it says I'm downloading at 25mbps and uploading at about 3mbps, so that's pretty fast...
...on my PC however, it says im downloading at 3 mbps and an error comes up when the upload phase starts.
what gives?
PostPosted: Wed Feb 17, 2010 6:34 am
What type of speeds do you get w/ a WIRED connection from that same desktop machine? I want to verify it's related solely to wireless and not a more general problem w/ the machine.
I would also run IPCONFIG from both the laptop (w/ wireless) and the desktop (w/ wireless) and compare them. Let's make sure they're configured similarly.
Please provide some more details as well about make/model of router, wireless client adapters, even the new build, etc. I need to get a better feel for the components, network topology, etc., something might get my attention. And some information about the OSes in use, versions, etc.
Btw, are you running any anti-virus, malware, etc., on that desktop?
PostPosted: Wed Feb 17, 2010 7:37 am
Hired Gun
Hired Gun
If you plug the computer back and use it wired does the problem go away? Are you using the most updated drivers downloaded from the manufactures website? Did you install any extra software that came with the Wireless card? If you did try uninstalling all the extra software and use only the driver.
PostPosted: Wed Feb 17, 2010 12:09 pm
Do you know if you are running add-on's within your browsers? This can really slow down browsing, even with a fast connection.
Cheers,
Kyler
IE8 Outreach Team
PostPosted: Wed Feb 17, 2010 6:43 pm
Wired
so its something wrong with the wireless connection
PostPosted: Wed Feb 17, 2010 6:54 pm
I just found the latest driver from the manufacturer's site....do I just save to my computer or do I need to do anything further?
PostPosted: Wed Feb 17, 2010 7:53 pm
Hired Gun
Hired Gun
You should be able to just install the new driver, then reboot.
