It is currently Wed Apr 01, 2015 7:32 pm
 Post subject: Setting up a network on a router
PostPosted: Sat Jan 22, 2005 2:06 pm
anyone have any information on this? for linksys router?
PostPosted: Sat Jan 22, 2005 2:48 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Wired or wireless. Not that hard. Pop in the setup disk and follow the on screen instructions. WE NEED MORE INFO THOUGH!!!!
PostPosted: Sat Jan 22, 2005 3:18 pm
wired I don't have a setup disk?
I want to connect 3 computers I think each has winxp. using a linksys 4 port router.
what more info do you need? Tell me and I will give it to you money
PostPosted: Sat Jan 22, 2005 3:32 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Money?? well the cash can be paypal'd to gamerfreak@gmail.com
But anyway
Look on the back of your router. There should be 6 ports on the back. One for power, one for WAN (your cable that comes in that takes u to the internet) and four other ports to hook up to you other computers. SO Take the ethernet cord from you cable modem and hook it into the WAN slot. Then Take 3 ethernet cables and hook them into the 4 ports on the back of the router. Then take the cord and hook them into the NIC "network interface card" In the back of the other computers. If you dont have a nic card you can get one for about 4 bucks at New Egg But most newer pc's have them intergrated. It would help to know the router model number becuase some require network configuration. Hope that helped,
-gamer
PostPosted: Sat Jan 22, 2005 3:39 pm
Befsr41 that the model.
sorry about about that, I didn't not mean money as in cash I meant
tell me how, money as in big boss dude who koknw all and holds the cash.
anyway what more do you need to know to help me setup a network in windows so I can see what files me room mate has on his computer, money?
PostPosted: Sat Jan 22, 2005 3:57 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
hahaha i knew that about the money i was just messing around. But year just hook it all up as i said above and then go to start>My computer> My Network Places (on the left menue bar)>Set up a home or small office network> and then follow the wizard. At the end of the wizard it will ask u if u want to creat a network setup disk adn select yes and make one. Then pop the disk in your roomates computer and configure that. Then you are ready to go. If wnat to share files right click the file you want to share files right click teh file u want to be shared and click properties. Afetr that click sharing and check "share this file on the network" and it will be accessable on the other computers through the "my network places" area as i directed you do before,
PostPosted: Sun Jan 23, 2005 6:51 am
Let the router handle your logon rather than any software on your computer. And setup the router as a DHCP server and all of your PCs to obtain an IP address autimatically, Once you get one PC connecting to the Internet through the router then it's just a matter of plugging the others in. All must be set to obtain an IP address automatically, and all must belong to the same Workgroup name if you want them to be able to see each other on the network.
PostPosted: Sun Jan 23, 2005 7:31 am
Contributing Writer
Contributing Writer
This guide damn near holds your hand through the process:
Home Networking Tutorial
