It is currently Wed Jan 28, 2015 11:15 am
 Post subject: Can Wireless router stand alone with the modem?
PostPosted: Fri Jan 21, 2005 6:04 pm
I've thought for a while that it could, but now that I'm trying it...can't do it.
Right now I have a PC hooked to the router directly through LAN, then it is the gateway to the internet for other PC's on the network.
What I thought I could do is this: Modem plugged into phone, router wired to modem, then transmit wireless to any machine with the reciever without one PC actually being hooked up directly with a LAN cable. Not true?
WRT54GS + WMP54GS + one PC.
PostPosted: Sat Jan 22, 2005 7:51 am
Were you drunk when you posted this?
PostPosted: Sat Jan 22, 2005 10:32 pm
No, why? Is it not clear what I'm asking?
Where not all network engineers...
PostPosted: Sat Jan 22, 2005 11:07 pm
team psycho or sumthin
i get it... you want a 100% wireless network/internet connection.
BTW i have no idea if you can do it or not...
PostPosted: Sun Jan 23, 2005 1:14 am
YES! I had just made some sort of assumption that the router has hardware and an OS, so it should be able to shout out without the need for a hard-link to one of the PC's.
PostPosted: Sun Jan 23, 2005 6:37 am
Yes it will work. You need to temporarily connect a PC to it to configure your login, WEP, and DHCP. Once that is done you can disconnect the PC.
PostPosted: Wed Jan 26, 2005 3:50 am
Thanks dude! I must be doing something wrong though. The connection process seems buggy. It says connected, but then I look at connections it says "not connected...click connect to..."
I've now set it up, turned off SSID broadcast, and auto connect...nothing. I'll keep playing now that I know it's possible. Thanks again!
PostPosted: Thu Jan 27, 2005 2:12 am
Durrr...I got it. I just needed to do some other type of stuff to get it to work with my ISP.
But if anyone else has issues with a Linksys Wireless router, just use this thing:
http://www.linksysfix.com/check/index.html?CallerID=KB
It's a great Noob Tool made for noobs like me!
