It is currently Fri May 24, 2013 9:38 pm
 Post subject: Access multiple networks
PostPosted: Fri Dec 04, 2009 10:56 am
Can somebody help me work through this thought?
I have the ability to access a wireless and wired network. There are a couple applications that I want to send through the wireless network (a specific browser for example, could be connected to VPN or not) and I want everything else to go down the wired network (outlook, windows explorer, IE, Office communicator, etc).
Is this possible?
PostPosted: Fri Dec 04, 2009 3:28 pm
You might be able to use FreeProxy. It can bind itself to a specific NIC, so the app you want to run through that one can go through the proxy (and out that NIC). Then make sure that the wired connection has a lower metric than the wireless connection so Windows will choose it for all other traffic.
PostPosted: Mon Dec 14, 2009 6:55 am
I will have to look into trying this.
