It is currently Tue Apr 21, 2015 3:56 am
 Post subject: How many knew Gmail did this?
PostPosted: Fri Jun 26, 2009 2:14 pm
Monkey Fed [PC]
Monkey Fed [PC]
Did you know they don't enable HTTPS by default? Interesting read in this article. Anyone who uses Gmail should check it out.
PostPosted: Fri Jun 26, 2009 4:56 pm
They've done that for the longest time. I've never had to worry about it cause I use Customize Google.
PostPosted: Fri Jun 26, 2009 10:13 pm
What does this mean in practical terms?
Added note. Messages that have been in your spam or trash folders will not be deleted after thirty days. I have seen them remain well over sixty days. If you click the link to delete messages a conformation window pops up and you have to click ok. If you simply select all and then click delete, poof, they're gone. No questions ask.
Another added note. If you change your settings to show more than ten hits per page in a google search it is not a permanent change. It will revert to ten per page in roughly 24 hours.
If you use one of the extensions or utilities available to access your unused storage in gmail, and then try to transfer to much at one time, they will suspend your gmail account for a minimum of 24 hours. I'm not sure what the exact limit is but I tried to transfer a directory with several hundred photos in it and got my hand slapped.
PostPosted: Sun Jun 28, 2009 11:33 am
Not true. Mine only reverts if my cookies are deleted.
PostPosted: Mon Jun 29, 2009 5:39 am
I hate that expression. It may not happen to you but that does not mean I am a liar. That may not be what you meant but it is what you said.
May not be true for you but it most certainly is true for me. All my other setting stick, only number of hits per page reverts. And it does it no matter what browser I use to change the setting.
PostPosted: Mon Jun 29, 2009 5:48 am
Well, no, that isn't true either.
He didn't call you a liar .. he said you're wrong (and I think that he is wrong in this case). That isn't the same thing. A lie is intentional whereas making a mistake is unintentional.
I'm not saying that either is the case here and I agree that saying 'not true' is annoying, but he isn't calling you a liar.
The assumption that you're incorrect because it works for him ... that is definitely annoying and a very common mistake made in PC forums. Just 'cause something works for A doesn't mean that it will work for B.
PostPosted: Mon Jun 29, 2009 3:46 pm
If you're not using HTTPS then it means your personal info is being transmitted in the clear for everyone to read.
PostPosted: Mon Jun 29, 2009 4:43 pm
I didn't call you a liar. Research your facts or add the disclaimer "this is what happens to me when I use [insert YOUR system / software configuration]". Or just be wrong gracefully. Sheesh, someone woke up on the wrong side of the keyboard.
@jip you should know I'm a girl by now or do you need proof? :)
PostPosted: Tue Jun 30, 2009 4:36 am
Well, you know that I'm not going to turn down proof! ;)
I didn't realise that it was your post that had upset TSG or I'd have used appropriate pronouns. My humblest apologies.
PostPosted: Tue Jun 30, 2009 7:43 am
So how does this translate when you're using an email client with gmail?
PostPosted: Thu Jul 09, 2009 4:16 pm
It doesn't. You use secure ports when using a client.
PostPosted: Fri Jul 10, 2009 3:09 am
I recommend Thunderbird. It's free and it works like a champ. If you didn't already know it, you can still use gmail as your smtp in an email client. You don't have to use your ISP. I have a separate paid for account and a corporate account provided by my employer and I use Tbird to download mail from both of them plus my gmail accounts and use gmail to send mail no matter which account I'm replying to.
