It is currently Thu May 23, 2013 7:04 am
 Post subject: Is this virus site very reputable or worth using?
PostPosted: Sun Jun 21, 2009 4:10 pm
I ran across this site and was wondering if it is worth messing with or actually works.
www.virustotal.com
PostPosted: Sun Jun 21, 2009 4:38 pm
Malware specialist
Malware specialist
Yeah, it's legit.
I use it when I need to find out what something is.
Be aware that it only scans the file when you upload it though.
PostPosted: Sun Jun 21, 2009 4:46 pm
Yeah I downloaded something today and tried it out on the site, it said it found a backdoor on 2 out of 41 scans.
I didnt know how reputable the site was or not on that since I know sometimes Ive had my antivirus tell me something was infected that wasnt.
PostPosted: Sun Jun 21, 2009 5:37 pm
Malware specialist
Malware specialist
Well, it's not the site itself that you need to worry about.
The site uses several scanners to scan the file for malware. 2/41 isn't that good of a detection, so unless you really think it's bad (or if it is a popular security software), I wouldn't worry about it.
PostPosted: Sun Jun 21, 2009 7:14 pm
Wel my only concern was if it really worked or not, the site that is.
And yeah I saw it scanning it with different AV programs and it said out of 41, 2 detected a problem with the program I uploaded to scan. Then I scanned the file with my avg and it said it was clean.
Although I am not sure what you meant by 2/41 isnt a good of a detection hehe.
PostPosted: Sun Jun 21, 2009 7:42 pm
Cause the majority didn't detect anything, it may have been a false-positive.
PostPosted: Sun Jun 21, 2009 7:48 pm
Ah ok, thats what I figured.
Thanks.
