It is currently Sat Mar 28, 2015 6:43 am
 Post subject: bookmark location in firefox
PostPosted: Mon Jan 19, 2009 7:06 am
Million Club 5+ [PC]*
simple question really. I can't find where firefox stores my bookmarks. its always one of the most tedious things to re constitute my bookmarks whenever I re-install.
so does anyone know where it is?
PostPosted: Mon Jan 19, 2009 7:15 am
Monkey Fed [PC]
Monkey Fed [PC]
What OS? I know in XP it's under Users/Yourusername/application data/mozilla/firefox...or something similar. I'm not sure where they are in Vista.
I use Firefox and an add on called Foxmarks. You sign up with a username and password, then upload your bookmarks to Firefox. Any time you do a new install/reload firefox, simply install Foxmarks, sign in, and VWOLLA!! All your bookmarks are there.
If you can't find them, something else to do would be to save your bookmark file somewhere you can find it. In Firefox, go to Bookmarks, Organize bookmarks. Then at the top, click the Import and Backup bookmarks, select where you want the file to be saved, and save it. Unless you're running IE, lol.
PostPosted: Mon Jan 19, 2009 8:20 am
That path sounds right, but why search or navigate. Just go into organize bookmarks and import and export to html from there.
PostPosted: Mon Jan 19, 2009 8:22 am
Million Club
Million Club
The FEBE extension can backup the bookmarks.htm and extensions to location that easy to find and has a schedule.
If you search for it may be in a hidden folder.
C:\Users\-USERNAME_\AppData\Roaming\Mozilla\Firefox\Profiles\qxnl38k7.default for Vista
PostPosted: Mon Jan 19, 2009 8:36 am
Team Member Top 250
Team Member Top 250
I use Foxmarks to synchronize and backup my bookmarks to and fro my different machines that I use often. Foxmarks can also synchronize your passwords too. This extension is highly recommended by me, myself, and I.
PostPosted: Mon Jan 19, 2009 9:02 am
thanks I will be sure to check out that addon later
I use both XP and W7.
I have looked in the folder you mentioned and the best I could find were backups. not my current bookmark list. so even if I wanted to use the backup I didn't know where to put it. it was very annoying.
as for the organized bookmarks tool... :oops: well I was unaware of that particular feature
thanks to all of you, I should have posted this thread months ago
PostPosted: Mon Jan 19, 2009 10:22 am
This!
PostPosted: Mon Jan 19, 2009 10:29 am
Million Club
Million Club
Foxmarks is simply amazing and useful.
