It is currently Sat Apr 25, 2015 1:07 am
 Post subject: Damn Adware? how the hell do i get rid of it?
PostPosted: Tue Dec 02, 2008 7:42 pm
I keep getting random porn adds and pop ups on maximumpc's site along with other sites. Its a pain in the ass... I tried spyware doctor (the free one that comes with google download pack) It found some things and deleted them but I'm still getting this shit. Every day it gets worse and I don't want credit cards stolen. Reinstall of windows would be a last effort but i would rather not.
Help please. It's annoying and I'm worried about the security of my pc.
PostPosted: Tue Dec 02, 2008 7:55 pm
Malware specialist
Malware specialist
This should really be in the Free Clinic, but I guess it works here too.
Since it is already confirmed malware, I'm going to have you skip HijackThis for now and skip right to SUPERAntiSpyware.
Please download SUPERAntiSpyware Home Edition (free version)
  • Install it and double-click the icon on your desktop to run it.
  • It will ask if you want to update the program definitions, click Yes.
  • Under Configuration and Preferences, click the Preferences button.
  • Click the Scanning Control tab.
  • Under Scanner Options make sure the following are checked:
    • Close browsers before scanning
    • Scan for tracking cookies
    • Terminate memory threats before quarantining.
    • Please leave the others unchecked.
    • Click the Close button to leave the control center screen.
  • On the main screen, under Scan for Harmful Software click Scan your computer.
  • On the left check C:\Fixed Drive.
  • On the right, under Complete Scan, choose Perform Complete Scan.
  • Click Next to start the scan. Please be patient while it scans your computer.
  • After the scan is complete a summary box will appear. Click OK.
  • Make sure everything in the white box has a check next to it, then click Next.
  • It will quarantine what it found and if it asks if you want to reboot, click Yes.
  • To retrieve the removal information for me please do the following:
    • After reboot, double-click the SUPERAntispyware icon on your desktop.
    • Click Preferences. Click the Statistics/Logs tab.
    • Under Scanner Logs, double-click SUPERAntiSpyware Scan Log.
    • It will open in your default text editor (such as Notepad/Wordpad).
    • Please highlight everything in the notepad, then right-click and choose copy.
  • Paste the logfile here and close the program.
PostPosted: Wed Dec 03, 2008 6:14 am
http://www.superantispyware.com
Generated 12/02/2008 at 11:15 PM
Application Version : 4.22.1014
Core Rules Database Version : 3661
Trace Rules Database Version: 1641
Scan type : Complete Scan
Total Scan Time : 00:56:03
Memory items scanned : 473
Memory threats detected : 0
Registry items scanned : 5788
Registry threats detected : 0
File items scanned : 64289
File threats detected : 11
Adware.Tracking Cookie
C:\Documents and Settings\John\Cookies\john@adcentriconline[2].txt
C:\Documents and Settings\John\Cookies\john@doubleclick[2].txt
C:\Documents and Settings\John\Cookies\john@windowsmedia[1].txt
C:\Documents and Settings\John\Cookies\john@advertising[2].txt
C:\Documents and Settings\John\Cookies\john@avgtechnologies.112.2o7[1].txt
C:\Documents and Settings\John\Cookies\john@2o7[2].txt
C:\Documents and Settings\John\Cookies\john@cgi-bin[2].txt
C:\Documents and Settings\John\Cookies\john@msnportal.112.2o7[1].txt
C:\Documents and Settings\John\Cookies\john@atdmt[2].txt
C:\Documents and Settings\John\Cookies\john@statcounter[1].txt
C:\Documents and Settings\John\Cookies\john@kontera[2].txt
PostPosted: Wed Dec 03, 2008 6:16 am
still getting same problem... some ads on web pages mpc for example get removed are replaced with other ads (look fake) and there is a little bar at the top saying click here to remove ads.
PostPosted: Wed Dec 03, 2008 7:47 am
Team Member Top 1000
Wait are there ads on the site? That is normal. There's a difference between popups and ads.
I found a quick screen shot.
Do you mean there's an ad banner like at the top of the picture here? The Scion ad is the one I'm referring to. Ads do rotate on the site. If I'm totally wrong please correct me. But with your second post it sounds as if you are annoyed with the ads on the site. If you're using Firefox, download Adblock Plus.
AJ
PostPosted: Wed Dec 03, 2008 1:07 pm
Malware specialist
Malware specialist
Well that didn't detect much at all.
What sites (other than MPC) are you getting pop-ups on?
Unless you are experiencing what CTskifreak described.
PostPosted: Wed Dec 03, 2008 2:27 pm
This is what I am getting. I dont mind ads but this is a pain and if is the ads that max pc is supposed to have thats pathetic.
PostPosted: Wed Dec 03, 2008 5:15 pm
It is what I described. If you use Firefox, download AdBlock now. Save you a lot of hassle. That's not adware, it's just ads on the site.
Firefox 3.0.4 with AdBlock Plus 1.0
However, those ads look like a lot of porn. This is what IE7 looks like to me with out any ad blocker.
Hmmm.
AJ
PostPosted: Wed Dec 03, 2008 5:51 pm
sometimes ads are normal other times i get the porn crap... for years I have never seen any porn related add till now
PostPosted: Thu Dec 04, 2008 1:32 pm
ideas.... anyone?
PostPosted: Thu Dec 04, 2008 1:33 pm
Malware specialist
Malware specialist
Any custom DNS settings? Or an odd host file?
PostPosted: Thu Dec 04, 2008 1:49 pm
No... I do have DMZ enabled. But why wont these spyware programs detect and remove this... im an geting same ads on other sites including facebook and kijiji.ca
PostPosted: Thu Dec 04, 2008 2:43 pm
Malware specialist
Malware specialist
I'm not sure if this is malware. Though I'm not sure what is up with those porn ads.
Can you post the hosts file text here please? (C:\Windows\System32\drivers\etc). Open the hosts file with Notepad and just paste the text here.
PostPosted: Thu Dec 04, 2008 3:13 pm
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space. - dddddddddddddd---------
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
127.0.0.1 atwola.com
#68.178.151.28 delb.opt.fimserve.com # 728x90
#68.178.151.28 desk.opt.fimserve.com # 160x600
#68.178.151.28 demr.opt.fimserve.com # 300x250
72.167.163.234 www.google-analytics.com
#72.167.163.234 pagead.googlesyndication.com
#72.167.163.234 pagead2.googlesyndication.com
#127.0.0.1 as.casalemedia.com
#68.178.151.288 ad.yieldmanager.com
#68.178.151.288 ad.doubleclick.net
#72.167.163.234 ads.sup.com
68.178.151.28 view.atdmt.com
#68.178.151.28 rad.~LINK BROKEN BY MANAGEMENT~
##68.178.151.28 themis.geocities.yahoo.com
127.0.0.1 www.intuneads.com
127.0.0.1 KILLMEPLEASE.com
127.0.0.1 www.cifras.com.br
127.0.0.1 www.gshome.com
127.0.0.1 www.all-midi.com
127.0.0.1 www.directtabs.com
127.0.0.1 hg1.hitbox.com
127.0.0.1 ad.harmony-central.com
127.0.0.1 cdn1.tribalfusion.com
127.0.0.1 isg01.casalemedia.com
127.0.0.1 isg02.casalemedia.com
127.0.0.1 isg03.casalemedia.com
127.0.0.1 isg04.casalemedia.com
127.0.0.1 isg05.casalemedia.com
127.0.0.1 isg06.casalemedia.com
127.0.0.1 isg07.casalemedia.com
127.0.0.1 isg08.casalemedia.com
127.0.0.1 isg09.casalemedia.com
127.0.0.1 isg10.casalemedia.com
127.0.0.1 isg11.casalemedia.com
127.0.0.1 isg12.casalemedia.com
127.0.0.1 isg14.casalemedia.com
127.0.0.1 isg15.casalemedia.com
127.0.0.1 isg16.casalemedia.com
127.0.0.1 ads.PointRoll.com
127.0.0.1 icq.rambler.ru
#127.0.0.1 global.msads.net
127.0.0.1 distortica.com
PostPosted: Thu Dec 04, 2008 3:45 pm
Malware specialist
Malware specialist
Did you add any of those entries in the host file?
PostPosted: Thu Dec 04, 2008 4:08 pm
wouldnt even know how to.
PostPosted: Thu Dec 04, 2008 4:10 pm
Malware specialist
Malware specialist
Okay, I'm going to have you restore the default host file.
Download the HostsXpert 3.7 - Hosts File Manager.
  • Unzip HostsXpert 3.7 - Hosts File Manager to a convenient folder such as C:\HostsXpert
  • Click HostsXpert.exe to Run HostsXpert 3.7 - Hosts File Manager from its new home
  • Click "Make Hosts Writable?" in the upper right corner (If available).
  • Click Restore Microsoft's Hosts file and then click OK.
  • Click the X to exit the program.
  • Note: If you were using a custom Hosts file you will need to replace any of those entries yourself.
Restart the computer and try browsing web sites again.
PostPosted: Fri Dec 05, 2008 4:21 pm
spyware doctor found this
http://www.pctools.com/en/mrc/infection ... Virtumonde
PostPosted: Fri Dec 05, 2008 4:32 pm
Malware specialist
Malware specialist
What was the filepath of that detection?
PostPosted: Fri Dec 05, 2008 7:46 pm
OK so most ads seem to be gone.... and WOW it infected one of spyware doctors dll's! It took a few full system scans to find it im surprised it did.
