It is currently Sun Mar 01, 2015 3:12 am
 Post subject: Running two websites with one IP address - Redirect by URL
PostPosted: Mon Nov 17, 2008 1:46 pm
I want to know if it’s possible to host two websites on the same server using the same port (80) and IP address. I am limited to using Microsoft IIS 7.0 not apache, but I can run PHP on it. (One of the sites is Joomla based)
If I register two domain names to, example1.com and example2.com, to IP address xx.xxx.xxx.xxx is there a script I could run or an IIS setting I could change so that users are redirected to a different folder or index page based on which domain name they use? Also if this is done with a PHP script or something similar would search engines index both pages correctly?
I know similar results can be achieved with Apache by using Virtual hosts in the httpd.conf file, but unfortunately I don’t know if this is possible with IIS.
Thanks for the help
 Post subject: Re: Running two websites with one IP address - Redirect by U
PostPosted: Fri Dec 19, 2008 7:34 am
Super Mario Banhammer
Thanks for the help
It is possible with IIS and has been since IIS 5.0. You need to do some research on Subwebs and virtual folders in IIS as there are many many different ways to implement this and no one method is going to be right for everyone. Basically there are Identities for each website under IIS and depending on your needs you may want a url redirect like http://www.somedomain.com/subweb1.htm?=somenewsite.aspx and http://www.somedomain.com/subweb1.htm?= ... wsite.aspx or you may need to assign headers for a site (too many approaches to discuss here) or you may need http://www.domain1.com and http://www.domain2.com. There are also commercial applications and opensource applications that allow you to redirect onto their domains as either a subweb or a top level domain.
HTH
PostPosted: Fri Dec 19, 2008 7:40 am
Two websites on one server? Why not? Apache does that out of the box.
PostPosted: Fri Dec 19, 2008 8:48 am
Jipstyle the reason is this from the original post:
PostPosted: Fri Dec 19, 2008 8:50 am
Im assuming that he has requirements that say he must use IIS 7.0 or that he may not use Apache. Not sure why as Apache or Web Sphere are generally speaking more extensible than IIS
PostPosted: Fri Dec 19, 2008 9:00 am
I am perfectly aware of this, but unfortunately I can’t use apache, as I stated above.
For some reason one of the people who maintains the server is convinced that IIS is more stable than Apache. No idea why he just is.
I am having some success using host headers in IIS, but I see how it works out.
PostPosted: Fri Dec 19, 2008 9:28 am
Sorry, I missed that in your first post. My bad.
I don't understand why any web server is unable to serve more than one site using the same port. Makes absolutely no sense to me.
PostPosted: Fri Dec 19, 2008 10:33 am
Im guessing this guy is the owner of the hardware and licenses? If so, Im sorry I feel your pain. Perhaps if he isnt a complete fughead you could show him otherwise. If he is a complete fughead use The headers as you can and bite your tongue :)
