It is currently Sat Apr 25, 2015 3:45 pm
 Post subject: Software for making MP3 list?
PostPosted: Sun Jul 04, 2004 4:21 pm
I'm curious if there is a program out there that will automatically make a list of my MP3's for me, or will I have to manually make a list of them all?
PostPosted: Thu Jul 08, 2004 11:59 am
What media player do you use?
With Winamp you can click the button "MISC" at the bottom (it's next to the ADD, REM and SEL buttons) twice and you'll see the option "Generate HTML playlist"
-OR-
You can just hit "Ctrl + Alt + G" (just make sure the playlist is active)
PostPosted: Fri Jul 16, 2004 6:42 am
right now, I have Window's Media Player 9 - but winamp would be easy to download if what I have isn't capable of doing it. I just don't know how if it is.
 Post subject: Re: Software for making MP3 list?
PostPosted: Fri Jul 16, 2004 8:40 am
Here what I do (because I never knew or looked for the winamp option).
Open a command prompt (START > RUN > type "CMD" hit enter), and do a
dir > output.txt
That will create a file called output.txt in that directory with the contents of the "dir" command.
If you need the subfolders listed to, do a dir /s > filename
PostPosted: Fri Jul 16, 2004 1:35 pm
dir > output.txt
I tried to do that, but I seem to be having a problem. It won't recognize the directory when I try to get it into the my documents folder.... it tells me that " 'My' is not recognized as an internal or external command, operable program or batch file."
Admittedly, I haven't used DOS since high school so I may be doing something wrong. Or it may have something to do with my using Windows 2000.
PostPosted: Fri Jul 16, 2004 2:12 pm
Maybe this will help you. If you are keeping your tunes in the "My Music" folder, here are the steps to do this. Of course remember to use the /s if you need subs as well.
