It is currently Wed May 22, 2013 12:27 am
 Post subject: Sharing a CD/DVD drive over network?
PostPosted: Sun Nov 28, 2004 3:54 am
Is it possible to share a CD or DVD drive over a network (so that it can be used by another computer)?
PostPosted: Sun Nov 28, 2004 4:03 am
Yes you can. Just do the same steps you would do for sharing any other folder.
PostPosted: Sun Nov 28, 2004 4:52 am
And I can also install programs from the CD/DVD drive from a networked computer, right?
PostPosted: Sun Nov 28, 2004 7:37 am
Yep. Just make sure you direct it to the computer you're accessing it from.
PostPosted: Sun Dec 26, 2004 2:20 am
but can you burn???
(or you need to actually go onto the computer with the burner to do that)
PostPosted: Mon Dec 27, 2004 7:48 am
INFINITE vCORE
INFINITE vCORE
I actually once watched a DVD from a shared DVD-ROM on a different computer :)
