It is currently Fri Feb 27, 2015 5:34 pm
 Post subject: ASP/PHP web editor
PostPosted: Thu Oct 21, 2004 2:56 pm
my friend is looking for a web design editor that supports both ASP and PHP. the main features he's looking for are 'syntax highlighting' and the ability to comment/uncomment lines by highlighting the contents and apply (it adds // in front of each line in the selected area).
PostPosted: Mon Oct 25, 2004 4:51 am
Bitchin' Fast 3D Z8000*
That's a pretty good question actually. I'm not too sure what most PHP programmers use. Emacs or Vi perhaps? I think that Jext might support PHP.
PostPosted: Mon Oct 25, 2004 7:12 am
thanks, but he needs to work under Windows, no Linux knowledge whatsoever.
i think he's tried Jext and something was missing.
PostPosted: Mon Oct 25, 2004 2:49 pm
Check the php.org site. They might have a link to php friendly editors there.
PostPosted: Mon Nov 01, 2004 5:37 pm
Try Zend Studio.
http://www.zend.com
There's also EditPlus and UltraEdit.
PostPosted: Mon Nov 01, 2004 6:48 pm
savagecat wrote:
Try Zend Studio.
http://www.zend.com
i dno't believe that one is free, he actually mentioned it.
