It is currently Mon Apr 27, 2015 1:32 am
 Post subject: Hosts file vs directories
PostPosted: Fri Oct 01, 2004 4:08 pm
King of All Voodoo2 Cards
Can you use a hosts file to stop files within a directory from loading? Something like:
127.0.0.1 www.webpage.com/ads/
Seems a lot of news sites I go to are moving over to this format.
 Post subject: Re: Hosts file vs directories
PostPosted: Fri Oct 01, 2004 4:22 pm
I dont think so, I think it only handles domains. you could givei t a try but i think it will just end up killing the site.
PostPosted: Fri Oct 01, 2004 4:41 pm
That's what I figured
PostPosted: Fri Oct 01, 2004 9:18 pm
Team Member Top 100
Team Member Top 100
If you're using Firefox look for a plugin called adblock :)
PostPosted: Fri Oct 01, 2004 9:49 pm
EDIT: nvm, I shoulda checked first
PostPosted: Fri Oct 01, 2004 10:00 pm
Team Member Top 100
Team Member Top 100
Not true at all!
Not only can you block anything (not just images), you can do a wildcard.
I.e.
http://www.adserver.com/*
