It is currently Thu May 07, 2015 12:56 am
 Post subject: Port 80
PostPosted: Fri Sep 10, 2004 3:18 pm
Should I block it and if so how can it be done?
PostPosted: Fri Sep 10, 2004 3:26 pm
Im going to assume you are obviously talking about inbound port 80 traffic...and that you are not already using NAT, if you were it would most likely already be blocked.
Where did you want to block it? your router (at the demarc)? or at the PC..if the PC, which OS do you run?
 Post subject: port 80
PostPosted: Fri Sep 10, 2004 3:46 pm
On firewall tests they say port 80 is open and they say it ia security risk.
I do not know more than that. I have a combo wireless router/switch and pcs with xp pro and win2k.
PostPosted: Fri Sep 10, 2004 3:52 pm
King of All Voodoo2 Cards
It's open on the router because that's how you log into it to perform administrative tasks.
 Post subject: prt 80
PostPosted: Sat Sep 11, 2004 7:16 am
I just posted a reply. I don't know why it showed up as a new thread.
PostPosted: Sat Sep 11, 2004 3:35 pm
yea but you can block port 80 on the WAN side but have it open on the LAN side for configuration. It's prolly a good idea to turn off the setting that allows remote (via the WAN side) configuration on your router.
So you are running the test from a remote host (ie. a web site)? If so, then try looking through your firewall settings.
PostPosted: Sun Sep 12, 2004 8:45 pm
I judge you GUILTY!
I judge you GUILTY!
First find out what kind of router do you have.
What are you using to test your router as well.
In any case, with this information, I can help you, but most likely you're safe regardless.
