It is currently Wed May 22, 2013 11:56 am
 Post subject: IE, part deus
PostPosted: Thu Jul 01, 2004 2:44 am
Bitchin' Fast 3D Z8000*
http://www.microsoft.com/security/incid ... _ject.mspx
Quote:
The first issue has been addressed by Microsoft Security Bulletin MS04-013. The second is a recently discovered issue that Microsoft is currently investigating in order to provide a solution. Customers who are already following our safe browsing guidance significantly reduce their risk from this type of attack.
Have fun. Be safe. Always wrap it before clicking! :)
And remember to check yourself for infections....
Quote:
To determine if the malicious code is on your computer, search for the following files:
* Kk32.dll
* Surf.dat
Steps for Windows XP users:
  1. On the taskbar at the bottom of your screen, click Start, and then click Search.
  2. Under What do you want to search for? click All files and folders.
  3. Under All or part of the file name:
    type: Kk32.dll
    and then click the Search button.
  4. Under All or part of the file name:
    type: Surf.dat
If either of these files is present, your computer may be infected.
PostPosted: Sat Nov 06, 2004 1:26 am
Bump :twisted:
PostPosted: Sun Nov 07, 2004 8:49 pm
Flump. ;)
 Post subject: Re: IE, part deus
PostPosted: Mon Nov 08, 2004 9:21 pm
* Kk32.dll
* Surf.dat
Both of my Windows PC's where I use Crazybrowser (IE 'Shell'), rather than Firefox, are clean. :)
PostPosted: Tue Nov 09, 2004 12:59 am
TWBalls wrote:
* Kk32.dll
* Surf.dat
That is an old hole.... he bumped a message going back to July 1.
PostPosted: Tue Nov 09, 2004 4:54 pm
Doh!
Well, I've had the same installation since then, so I guess I should change it to 'They're still clean'. ;)
