It is currently Tue Mar 31, 2015 2:36 pm
 Post subject: Best Ad blocking add-on/extension for Chrome or Firefox
PostPosted: Fri May 17, 2013 9:36 pm
Before I start downloading random ad blocking add-ons, I was wondering which ones you prefer and which ones I should avoid. Just a quick glance and I see AdBlock, AdBlock Plus, Adblock Lite, Maximum Adblock and Simple Adblock.
Any advice is appreciated.
 Post subject: Re: Best Ad blocking add-on/extension for Chrome or Firefox
PostPosted: Fri May 17, 2013 11:38 pm
AdBlock Plus. If you want some extra security but don't mind whitelisting everything as you go, No Script is a good choice.
