It is currently Mon Jan 26, 2015 1:09 am
 Post subject: Slow internet speed
PostPosted: Fri Jun 28, 2013 1:33 am
i am getting very low internet speed how i can improve it i am using PTCL as ISP
 Post subject: Re: Slow internet speed
PostPosted: Fri Jun 28, 2013 12:32 pm
Moderator
Moderator
Call your ISP and pay more for faster speeds.
PostPosted: Fri Jun 28, 2013 12:41 pm
Phosphorous wrote:
Call your ISP and pay more for faster speeds. ptcl speed test
Ok i am planning to upgrade it but one of my friend told me that may be it is due to old landlines in your area. Now i am in doubt
PostPosted: Mon Aug 05, 2013 1:23 pm
or move out of the united states, 3yr ago we were #12 now we are #21 and falling fast
PostPosted: Mon Oct 07, 2013 10:40 pm
To increase your Internet speed you can follow these tips give below:
1. contact our ISP and get a latest speed plan from them. It's better way to increase our speed.
2. clear cookies from our browser
3. Delete unwanted files.
4. PC Optimization:
It is important to clean your PC regularly. It means a normal maintenance tasks such as, cleaning the disks, registry repairs and Disk Derangement
5. Reduce our bandwidth overhead
6 Scan With Latest Antivirus Program
7. Use Updated Web Browser
8.Install Anti virus software.
9.Consult with your Internet service provider to ensure that your modem is configured correctly.
After, completing this steps, you can check our internet speed from this site ScanMySpeed.com
PostPosted: Tue Oct 08, 2013 3:43 pm
this might be a little advanced but i opened my cable modem(i own it) and installed a cooling fan, it seems that some of the "innards" get hot and start to malfunction, it worked for me. btw if u google/duckduckgo you can find sites/tubes that show you how to etc.
hope this helps
PostPosted: Thu Jan 30, 2014 2:52 am
I recommend you to read this article:
http://www.wikihow.com/Increase-Internet-Speed
Change also the password of your wifi router. If you don't use the last encryption technology, it is possible your neighbour is using your connection for free.
