It is currently Mon Mar 02, 2015 8:54 am
 Post subject: html or frontpage
PostPosted: Wed Aug 04, 2004 7:28 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Should i go ahead and design my page with front page or stick it out with html
PostPosted: Thu Aug 05, 2004 6:07 am
I think you should use cobal. It's this super-hot new web programming language.
 Post subject: Re: html or frontpage
PostPosted: Thu Aug 05, 2004 6:56 am
use FrontPage if it's faster, than clean it out with Notepad/Wordpad.
PostPosted: Thu Aug 05, 2004 5:35 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
good idea
PostPosted: Fri Aug 06, 2004 2:33 am
yeah, frontpage throws A LOT of junk code in with it, that's what i generally do especially when dealing with tables, make the layout and such with frontpage real quick, then go in and edit everything out that's crap ...
PostPosted: Fri Aug 06, 2004 12:30 pm
many hardcore HTML coders like to do it using notepad. I am one of them.
PostPosted: Fri Aug 06, 2004 12:45 pm
Monkey Federation (Top 10)*
I second that. Front Page is the Suck!
PostPosted: Fri Aug 06, 2004 10:15 pm
i used to do that too, but after making an 80 page site completely in notepad, frontpage just seems to speed things up quite a bit ...
PostPosted: Wed Aug 25, 2004 10:44 pm
Front Page is crap. Aboslute. Frontpage 2003 has some good redeeming qualities, but my choice for you my son is Dream Weaver MX or MX 2004.
Where would you get a silly idea that MS could get web authoring right?
PostPosted: Wed Aug 25, 2004 10:48 pm
Notepad is useful for tweaking. Total development...you obviously don't create a lot of content.
One nice thing about Notepade is you can keep the crap to a minimum. However conceptually there's nothing better than developing in Dreamweaver MX or MX 2004 - no not a cheap solution, but it works, its powerful, and the content management is top rate.
Just the content management, in my opinion, is worth it. And you can still do the coder's view if you want a notepad like experience.
PostPosted: Wed Aug 25, 2004 10:52 pm
Amen brother. I have a 200 page site I'm working on now http://www.geocities.com/wolfmannjack/ (by the end it'll be a lot bigger than 200 pages) and if I had to do it from notepad I'd be a lot worse off. It really is just basic HTML, but it's tables based and that's a lot of extra, unnecessary work - no wonder frames were used so much in the early days. For that reason I am using frames at this site for navigation to save bandwidth and load times http://www.chungwahmartialarts.com (it should be completed Oct 1).
PostPosted: Wed Aug 25, 2004 11:14 pm
hell yeah, i still use tables and stuff all the time, i havnt moved on to the "new" stuff yet. i use Dreamweaver MX also, but i do still use frontpage if i wanna throw sumthin together real quick. then i use notepad or the code views to clean up the code cuz most of the time they throw in a lot of unneccesary BS code.
PostPosted: Thu Aug 26, 2004 4:49 am
Over the past month I switched from Frontpage to Dreamweaver MX 2004.. all I have to say is WOW... Dreamweaver offers so much more compared to Frontpage!
PostPosted: Thu Sep 02, 2004 8:14 am
You definitely have to give DreamWeaver MX a chance. I bought the program a couple of months ago after years of slaving through Notepad. You can save so much time this way, the money is well worth it.
PostPosted: Thu Sep 02, 2004 1:32 pm
Dreamweaver > Frontpage.
As for notepad ... NO serious coder uses notepad. WTH are you people thinking? Use an ide of some sort .. but notepad? For anything larger than a personal webpage, you're limiting yourself in a big way.
Also ... anyone who uses 'hardcore' and 'HTML coder' in the same sentence had BETTER be grinning while they do it.
</elitist rant>
