It is currently Sun Mar 29, 2015 9:47 am
 Post subject: Need Website Access Help
PostPosted: Sun Aug 19, 2012 5:45 am
I can get onto this website just fine. Go through page by page but when I go to add my reply, I get the below message:
"The page you are trying to access is restricted due to a security rule.
If you believe the security rule is affecting the normal operation of your website,
you can disable it by adding the following lines to your .htaccess file:
<IfModule mod_security.c>
# Turn the filtering engine On or Off
SecFilterEngine Off
</IfModule>
Can anyone help with this or explain why it is coming up? Thanks.
 Post subject: Re: Need Website Access Help
PostPosted: Mon Aug 20, 2012 4:23 am
What browser are you sporting? How old are you? Looks like your parents have you restricted on OpenDNS. :lol:
PostPosted: Mon Aug 20, 2012 7:35 am
I surf the web using a proxy server so I think it has something to do with that.
Does anyone know what the above means and/or what can I do???
