It is currently Tue Apr 21, 2015 7:09 am
 Post subject: Serving it up
PostPosted: Mon Mar 14, 2005 5:59 pm
Is there a way to turn my computer and cable connection into an ftp server? or host a webpage on it so that people can download information from my computer?
PostPosted: Mon Mar 14, 2005 6:06 pm
Yup, you can "turn-on" IIS in WindowsXP and use it to host both a FTP and Webpages. Go to Control Panel, select Add/Remove programs. Click on Add/Remove Windows Components. Find "Internet Information Service (IIS" in the list, click on it, select Details, and select the services you want to enable. You can then use a Dynamic DNS service such as No-ip.com so that when/if your IP address changes, your friends can still find your site.
If you are not familiar with setting up IIS you can use the Windows Help, and the many various tutorials around on the net for further information.
PostPosted: Wed Mar 23, 2005 1:14 pm
sorry i have to ask....
I'm trying to do the same thing.
So once I do what you recomended-> I just leave the system ON and thats it?
-If I have a router, should I keep any ports open?
-turn firewall OFF
thanks
J-P
