It is currently Wed Jun 19, 2013 7:06 pm
 Post subject: How to Remove Your Google Search History Before...
PostPosted: Tue Mar 06, 2012 11:01 am
How to Remove Your Google Search History Before Google's New Privacy Policy Takes Effect
The EFF (Electronic Frontier Foundation) has a simple article up showing you how to remove your Google search history before the new privacy policy takes effect. It is important to note that disabling Web History in your Google account will not prevent Google from gathering and storing this information and using it for internal purposes. All you need to do is:
1. Sign into your Google account
2. Go to https://www.google.com/history
3. Click “remove all web history”
4. Click “ok”
If you need more information including a walk-through with photos please check out the details. You will need to do this for each Google account you have.
 Post subject: Re: How to Remove Your Google Search History Before...
PostPosted: Tue Apr 17, 2012 4:29 am
Google Search History Can Also Be Manually Removed When Any Search Keywords Is Been Typed On The Search Text-bar Or Search Index Following The Down Arrow Key And Delete Button.
