I've just re installed windows XP Pro and i re installed my D-Link DWA 160 USB Adapter. the problem is that it won't stay connected for more than a few seconds. I have installed and uninstalled the USB adapter several times ,still the same result no connection. I tried , as D-Link suggested that i disable my antivirus first before installing my USB Adapter, still the same result. I've even tried another D-Link DWA 160 from the same network, still the same result. I've even tried using a Cat5e cable direct to the router and got the same results. So my question is what else can i do or try that would allow me to get a constant connection?. My router is a D-Link 825 dual band router. I would appreciate any and all help. Thanks Shawn
