It is currently Mon May 04, 2015 7:30 pm
 Post subject: You may want to drop Dropbox
PostPosted: Sat May 14, 2011 8:23 am
Don't buy the bit from anyone, nothing is the cloud is secure.
 Post subject: Re: You may want to drop Dropbox
PostPosted: Sun May 15, 2011 9:30 pm
Quote:
David Gewirtz’s assertions were correct. You shouldn’t use Dropbox if you have something to hide.
Data held in Dropbox was and still us vulnerable to inspection by U.S. authorities.
So?
Honestly, if you're stupid enough to share anything incriminating in the 'cloud', you deserve to get caught.
PostPosted: Tue May 24, 2011 8:21 pm
PSN data found by anonymous hackers that results in the shutting down of content access = rage
Dropbox data found by anonymous U.S. authorities that results in the shutting down of content access = n.p. bro!
PostPosted: Tue May 24, 2011 9:46 pm
PSN data includes credit card numbers.
Argument fail.
PostPosted: Sun Jun 12, 2011 12:54 pm
Access to your financial assets by hackers = rage
Access to your financial assets by U.S. authorities = s'aright, man!
PostPosted: Sun Jun 12, 2011 8:49 pm
If you put your financial assets into the cloud, you're an idiot. Period.
PostPosted: Tue Jun 21, 2011 5:28 am
More incompetence from the Cloud Clowns...
PostPosted: Wed Jul 06, 2011 5:12 pm
Secare non potes faciem meam; nunc uicti ratione hominis.
PostPosted: Fri Jul 08, 2011 2:42 pm
Does doing any of your banking and/or investment activities online qualify as doing finances in the "cloud"? If it does, then I'm about as stupid as they get!
PostPosted: Sat Jul 09, 2011 9:35 pm
No, it doesn't.
If you store CC or account numbers online, that's dumb .. But using your bank's online tools should be fine.
PostPosted: Sun Jul 10, 2011 2:18 am
I understand now, it's the storage of sensitive information online that is the problem, not necessarily the use of it, especially if the use is in the secure https mode. Sorry for being a bit confused at first.
PostPosted: Sun Jul 10, 2011 8:53 am
Exactly.
There's no need to apologise, though :)
PostPosted: Thu Sep 08, 2011 4:55 am
Right, cloud is just like in real life. You don't leave your car opened. The same with the data - some things may be shared, for some it's not possible.
