It is currently Mon Jan 26, 2015 5:51 am
 Post subject: IPv6 compatibility
PostPosted: Tue Jun 07, 2011 2:10 pm
Since IPv6 test day is tomorrow, I was wondering if anyone knows anything about compatibility, ie, routers, modems, ect.
Thanks in advance!
 Post subject: Re: IPv6 compatibility
PostPosted: Sun Jun 12, 2011 11:37 pm
Just about everything save a few niche devices will work and you won't even notice. If you're at all worried about it check for some firmware updates. It's fairly easy for routers you just have to go to your home portal web page.
Otherwise if you're device is +3 years old you may want to check for any relevant software. The change shouldn't be as dramatic as you think. And FYI: IPV6 gets re-rolled out on a large scale multiple times a year. Everything is getting patched and released and updated in big chunks because, well, that's how you have to do something that big.
