It is currently Tue Jan 27, 2015 2:53 am
 Post subject: Downloading Torrents Question
PostPosted: Wed Dec 08, 2010 8:22 am
I notice when there are more Seeders than Leechers, I get great downloading rates but when the Leechers outnumbers the Seeders the bandwidth is not near as good. Is this the way it is supposed to be? If so, can someone explain the reason why? Thanks.
 Post subject: Re: Downloading Torrents Question
PostPosted: Wed Dec 08, 2010 9:53 am
a couple reasons; The main one being bandwidth priority. If you're leeching you're using up most of the bandwidth on the download and only a fraction of bandwidth for outgoing data (or upload). Multiply this concept times however many people are leeching and collectively the throughput of 'outgoing' data is a lot less.
If someone is Seeding they have all the available bandwidth allocated to uploading (theroetically). Some of these factors are affected by the users settings in the bit torrent client but the concept should be clear.
Also, if you have a ton of people Leeching and much fewer people Seeding there's a good chance that many of you will have identical "pieces" of the data. It's up to those much fewer Leechers with the missing data to prioritize and send that missing data your way. This also reduces the speed at which your file downloads.
I'm sure someone may add or clarify to this, but the gist is there.
PostPosted: Wed Dec 08, 2010 4:34 pm
Team Member Top 1000
you can usually tweak your bittorrent client a bit to improve speeds, especially if you've got a high bandwidth connection, you can run have a much higher # of connections and connected peers.
PostPosted: Thu Dec 09, 2010 10:40 am
I always see posts next to the torrent file from other downloaders requesting people to "seed" as much as they can. Obviously seeding is part of the process where people make files on their pc available to download.
Am I to assume leechers are the people downloading the torrent??
PostPosted: Thu Dec 09, 2010 12:53 pm
You are correct in your assumption.
Seeders = Computers that have the complete file
Leachers = Computers that do not have the complete file (ie ones that are still downloading the file)
PostPosted: Sun Dec 12, 2010 3:31 pm
Leechers (good name)
