It is currently Sun Feb 01, 2015 2:56 pm
 Post subject: Notice Something Different About Google?
PostPosted: Fri Mar 12, 2010 4:39 pm
Take a look at the following screenshot, I went to do a search on Google, and that's what showed up, could it be Caffeine popping up as a test or is it because I'm signed into Google, although I have been before and what's showing in the screenshot has never happened before?:
PostPosted: Fri Mar 12, 2010 5:01 pm
Monkey Fed [PC]
Monkey Fed [PC]
Predictive typing. Google has it. Mine does the same thing.
PostPosted: Fri Mar 12, 2010 5:02 pm
I'm not talking about that, I know it does that, look at the screenshot again.
PostPosted: Fri Mar 12, 2010 5:16 pm
Malware specialist
Malware specialist
You need to be a tad bit more specific, all I see is the predictive google searching as well.
PostPosted: Fri Mar 12, 2010 5:49 pm
Monkey Fed [PC]
Monkey Fed [PC]
There is nothing in that screenshot that is any different from what I see every day. Except for the Canada part, but that's because you're on google.ca, and not com.
