It is currently Sat Apr 18, 2015 4:00 pm
 Post subject: C++ Array help
PostPosted: Sun Oct 18, 2009 9:31 am
Team Member Top 1000
I'm writing a numerical palindromes program and am stuck on a function that sees if a particular number is a palindrome
bool checkIfPalindrome(int input)
   const unsigned int inputLength = digits(input); // computes the number of digits in "input"
   char input1[inputLength];
   char input2[inputLength];
   itoa(input, input1, 10); // turned input into an array of chars
   int lastIndex = inputLength - 1;
   int currentIndex = lastIndex;
   for(int i = 0; currentIndex >= 0; i++, currentIndex--) //turns the second array into a mirror of the first
      input2[i] = input1[currentIndex];
   //now see if the 2 arrays are equal
   for(int i = 0; i <= lastIndex; i++)
      if(input1[i] != input2[i])
         return false;
   return true;
int digits(int n) //computes number of digits in an integer
   int i;
   if(n == 0)
      return 1;
   for(i = 0; n; ++i)
      n /= 10;
   return i;
and I'm getting the following errors:
Quote:
main.cpp(37) : error C2057: expected constant expression
main.cpp(37) : error C2466: cannot allocate an array of constant size 0
main.cpp(37) : error C2133: 'input1' : unknown size
plus the same errors for "input2"
the digits function should never return 0, not sure how to convince the compiler of that, plus the last error, I'm assuming that has to do with the program not knowing how much memory to allocate at run time
Visual Studio 2008 EE
PostPosted: Mon Oct 19, 2009 4:20 am
You can't assign a dynamic size to the array. It has to be constant.
If you truly need a dynamically sized array, look into using vectors.
PostPosted: Wed Oct 21, 2009 9:53 pm
Also, remove the "const" modifier for the declaration of inputLength. You are trying to assign a dyanmic value to what should be a static variable. Use const only for known and unchanging values. For example, let's say you are creating a program/methods that calculate different measurements of a circle like area and circumference. Both use the value of PI and that value is always the same. Then you would declare the variable PI as a constant equaling 3.14....
