It is currently Sat May 25, 2013 1:47 pm
 Post subject: A little help with programming in Linux... in C
PostPosted: Mon Oct 26, 2009 8:05 pm
Just so I can get this out of the way, yes it's for class. But no, I'm not asking you to do all of it. I just need help with this problem.
I'm basically creating a shell that coincides with my OS class, and it should have the basic features of a regular shell. The only problem I'm having with is running the the following commands:
< /home/ma/cs/Data1/input1 > your.outputb tr a-z A-Z &
>your.outputf</home/ma/cs/Data1/input1 tr a-z A-Z
This is injected into my program as a typical input redirect (i.e., p2 < input). My program does the first line correctly. The second part? Not so much. It leaves a blank file half the time. Sometimes it works, sometimes it doesn't. But I need this to work all the time. My execution part of the code is as follows (the redirects work so I know it can't be that)
//Fork shell and execute command
            if( (kidpid = fork ()) == 0) //CHILD PROCESS
               for( i = 0; i < c ; i ++)
                  if(compare(argv[i], "\0"))
                     break;
                  newargv[i] = argv[i];
               newargv[c] = NULL; //Last argv should be nulled
               if((execvp(newargv[0], newargv))<0)
                  perror("Could not execute");
               exit(1);
            else if (kidpid == -1) //FORK ERROR
               perror("Cannot fork\n");
            else //PARENT PROCESS
               if(*background == 0)
                  wait(&child_pid);
                  dup2(std_in, STDIN_FILENO);
                  dup2(std_out, STDOUT_FILENO);
               else
                  x = 255;
                  int directory = 0;
                  for(i = 0; i < STORAGE ; i++)
                     if ( argv[0][i] == '\0')
                        break;
                     else if(argv[0][i] == '/')
                        directory = 1;
                        x = i+1;
                     if(x+i == STORAGE)
                        break;
                     else if ( directory == 1)
                        argv[0][i] = argv[0][x+i];
                  printf("[ %s ]\t[ %d ]\n",argv[0],getppid());
Apparently this program is very finnicky depending on where its run. I developed this in Ubuntu, only to realize that once it's uploaded to the server that it needs to run on, it works 90% correctly. So if you notice anything strange, that's why.
Also the part of the code that starts with x = 255; was a design spec... Unless someone else can tell me a quick and dirty way to get the process name.
PostPosted: Wed Nov 11, 2009 12:12 am
Bitchin' Fast 3D Z8000*
"It leaves a blank file half the time. Sometimes it works, sometimes it doesn't. "
I don't have time to review your code at the moment, but it sounds like you may have forgot to flush the file buffer.
