It is currently Thu Jan 29, 2015 3:16 am
 Post subject: Temperature program
PostPosted: Fri Sep 25, 2009 11:01 am
Hey guys, this is my literal first program ever written without using my reference book or any other help. Just wondering if anyone could give some constructive criticism on it.
#include <iostream>
int celtofahr(int);
int main()
using namespace std;
int cel;
cout << "Please enter the temperature in Celcius: " << endl;
cin >> cel;
int fahr = celtofahr(cel);
cout << cel << " degrees in Celcius = " << fahr << " degrees in Fahrenheit." << endl;
return 0;
int celtofahr(int ctf)
return 1.8 * ctf + 32;
Any comments would be helpful. Thank!
PostPosted: Fri Sep 25, 2009 11:49 am
Please use the [ code] tags when posting code.
Eg:
#include <iostream>
int celtofahr(int);
int main()
int cel;
cin >> cel;
return 0;
Otherwise, your code looks like a standard little program written for an Intro to Programming course. If it works, thumbs up!
PostPosted: Fri Sep 25, 2009 3:04 pm
yea, looks good. The only thing I can think of is your naming scheme, Everybody has their own, but I personally don't use abbreviations, i think it looks more professional.
But if it works for you, good job!
 Post subject: Re: Temperature program
PostPosted: Fri Sep 25, 2009 7:38 pm
Let's say you take a thermometer out of your mouth and it says 37 degrees Celsius. You convert it to Fahrenheit, is the temperature accurate? Or are you sick/ill?
PostPosted: Fri Sep 25, 2009 7:54 pm
Shutout makes a good point. I see no reason to abbreviate any names in a program and many reasons not to do so. Now that we can autocomplete any name, it makes no sense to use a name like celtofahr when celciusToFahrenheit is possible.
PostPosted: Sat Sep 26, 2009 4:06 am
Good point. I'm not sure why I used an abbreviation, after shoutout mentioned that I remembered that C++ imposes no limit on the length of a variable name. I'll remember that next time, thanks guys.
PostPosted: Sun Sep 27, 2009 7:01 am
So I kept everyones advice in mind while completing the last project I had. It's a program to calculate your Body Mass Index based on your height and weight. Again any critism is good. Thanks in advance.
#include <iostream>
#include <cmath>
int main()
    cout << "Please enter your height:______\b\b\b\b\b\b";
    int heightInInches;
    cin >> heightInInches;
    cout << "Please enter your weight in pounds:______\b\b\b\b\b\b";
    int weightInPounds;
    cin >> weightInPounds;
    double heightInMeters = heightInInches * 0.0254;                        // these two statements are for converting the height
    double weightInKilograms = weightInPounds / 2.2;                        // and weight to metric units
    double heightInMetersSquared = pow(heightInMeters, 2);
    long double bodyMassIndex = weightInKilograms / heightInMetersSquared;
    cout << "Your BMI is: " << bodyMassIndex << endl;
    return 0;
[/code]
PostPosted: Wed Nov 11, 2009 1:25 am
Bitchin' Fast 3D Z8000*
These are relatively simple programs...
Putting the namespace statement inside the main block is a bit odd.
* at least it _used_ to be odd, hopefully one of the younger bit-twiddlers will let me know if something changed!
PostPosted: Wed Nov 11, 2009 5:27 am
It isn't a matter of professionalism. It is a matter of readability. With auto-complete and intelli-sense type functionality in modern IDEs, having variable and function names that are 20 characters isn't a big deal.. you type the first 4 and hit a couple key short cuts and boom it is filled in for you. Much easier to read.
I'd say it is odd... lol
#include <iostream>
#include <cmath>
int main()
    int heightInInches;
    int weightInPounds;
    return 0;
Other than being piddly little example programs, things are looking good! Getting your style down early is important. I wish I had that focus because I wrestle with bad style sometimes even today.
PostPosted: Wed Nov 11, 2009 7:23 am
Thanks to all of you for the help. I was just piddling with C++ to get the hang of it before I started school. My curriculum starts with HTML and Java servlets then moves on to Java Programs, then to C++ and C# programs. But everyone has been helpful, thanks again!
