It is currently Sat May 25, 2013 7:30 am
 Post subject: Countdown Timer in Dos
PostPosted: Thu Jun 04, 2009 12:20 pm
Okay, so im making a Batch file to backup some data daily. i have the backup procedure all set and ready to go, but it always fails and i pinned it down on the fact that making a new folder on a server takes a little time. i was wondering if someone could give me a hand with making a countdown timer that counts to 5 seconds then runs the rest of the program.
Thanks everyone!
PostPosted: Thu Jun 04, 2009 8:03 pm
Because there is no batch file command that "sleeps" or counts down, you have to improvise a little. The simplest way to delay for 5 seconds is to run a program that takes 5 seconds to execute.
fairly simple...
#include <windows.h>
int main() {
    Sleep(5000);
    return 0;
I compiled it for you, get it here:
http://dl.getdropbox.com/u/1203786/5seconds.exe
Stick the exe in the same directory as the batch file... i'm assuming you can take it from here...
@echo off
echo HELLO
5seconds.exe
echo WORLD
pause
qa9b
PostPosted: Fri Jun 05, 2009 6:32 am
This works PERFECTLY! Thanks a lot!
is this
int main() {
    Sleep(5000);
    return 0;
whats in that exe?
Thanks!
PostPosted: Fri Jun 05, 2009 6:49 am
Yes, that snippet of c++ is what's in the executable. It calls the windows function Sleep(), which takes an argument in milliseconds. All the c++ program does is wait 5 seconds and then end. You could compile it yourself if you want (or change the delay) if you have a c++ compiler.
PostPosted: Fri Jun 05, 2009 7:09 am
Here's a more versatile version:
#include <iostream>
using namespace std;
int main(int argc, char *argv[]) {
    if (argc != 2) {
       cout << "Error. This program requires a single argument in milliseconds to specify \nthe delay interval\nType \"delay.exe delay\", where \"delay\" is in milliseconds";
    Sleep(atoi(argv[1]));
    return 0;
DL: http://dl.getdropbox.com/u/1203786/delay.exe
This version accepts a command line argument (in milliseconds) that specifies the delay period. So if you wanted to delay for 2 seconds instead of 5, the batch file would look like this:
@echo off
echo HELLO
delay.exe 2000
echo WORLD
pause
PostPosted: Mon Jun 08, 2009 11:15 am
Ahh, thats brilliant! I dont know much programming, just my DOS knoweledge, which is pretty much just limited to Windows XP's "help" in the command prompt. But that second option is definatly the way to go for me! Thanks!! Ill try it out tomorrow when i get some free time!! :D
