It is currently Fri May 24, 2013 4:40 am
 Post subject: Got a quick question about C#
PostPosted: Sun May 31, 2009 10:43 am
What is the benefit of creating your own namespace?
 Post subject: Re: Got a quick question about C#
PostPosted: Sun May 31, 2009 12:34 pm
One major benefit is that you are preventing name clashes with system and other classes.
For example:
Microsoft's .NET classes include a class called String. It represents a string of characters, like "foo".
Now suppose that you are working on a program for a company that makes craft supplies. In a momentary lapse of reason, you create a String class to represent a ball of yarn. If you put this into your own namespace, you can still use it and the System.String class perfectly. However, if you decide to put your String class in a global namespace, it can cause some problems at compile time (And maybe runtime too, I'm not sure about that).
PostPosted: Mon Jun 01, 2009 4:21 am
I use them to let me group things logically together. Most of my solutions have projects laid out like this:
ProjectName.Application
ProjectName.Common
ProjectName.DataAccess
ProjectName.Business
It works well, keeps things organized, and I only need to include the project (namespace) that I need at a given level. The application level never should need the DataAccess because the Business layer handles opening and saving the data through it's objects, etc.
PostPosted: Mon Jun 01, 2009 7:46 am
namespaces allow you to logically group related classes together. It allows you to create a hierarchy of classes in addition to relating classes.
Namespaces Tutorial
PostPosted: Tue Jun 09, 2009 7:20 am
Super Mario Banhammer
Grouping related classes in a logical manner is always a good thing. Preventing naming clashes or ambiguity is another good reason. A third reason would be for specialized classes in the area of inheritance and class polymorphism As an example:
If you have classes in two different namespaces that one of the class relies on for input or a property of some kind then you might see something like the following:
namespace Test.CSharpExample.ImplementsA
     public class Hello
         private string m_Message;
          public string Message
              get
                   return m_Message;
              set
                  m_Message = value;
namespace Test.CSharpExample.InheritsB
    abstract class Hello   // Abstract class
        protected string m_Message = "";
        public abstract void AbstractMethod();   // Abstract method
        public abstract string Message  {get;}{set;}
and if you would like to derive the properties and methods of the InheritsB Hello class or instance the ImplementsA Hello class:
using System;
using System.Collections.Generic;
using System.Text;
using Test.CSharpExample.ImplementsA;
using Test.CSharpExample.InheritsB;
namespace Test.CSharpExample.DerivedOrImplementedClasses
     class DerivedClass : Test.CSharpExample.InheritsB.Hello
        public override void AbstractMethod()
                m_Message = "Hello, World";
        public override string Message   // overriding property
             get
                 return m_Message;
             set
                 m_Message = value;
     static void Main()
        DerivedClass o = new DerivedClass();
        Test.CSharpExample.ImplementsA.Hello o2 = new   Test.CSharpExample.ImplementsA.Hello();
        o.AbstractMethod();
        o2.Message.ToString();
        Console.WriteLine("{0}", o.Message);
        Console.WriteLine(o2.Message.ToString());
As you can see you can do both within the same operator class. With namespaces you can logically organize, provide a way to distinguish between differing subtypes of a class to avoid inconsitency or ambiguity, provide yourself with a shortcut to writing cleaner more readable code and you can provide for both inheritance and implementation within the same namespace :D
