It is currently Sat Jan 31, 2015 2:54 pm
 Post subject: Calculate angles with Java
PostPosted: Sat May 30, 2009 5:52 pm
Hey, I'm doing a simple trajectory calculation in Java and it seems that the Math.sin method is giving me a negative number. Not only that but the number i'm looking for is all wrong.
 Post subject: Re: Calculate angles with Java
PostPosted: Sat May 30, 2009 6:16 pm
maybe your algorithm is wrong. Post your code here for people can see it.
PostPosted: Sat May 30, 2009 6:23 pm
Also remember that all Java's trig functions work in radians. If you're doing degrees, then it won't work.
PostPosted: Sat May 30, 2009 6:49 pm
it's just Math.sin(angle) so how do I get it into degrees? Math.toDegrees();?
PostPosted: Sat May 30, 2009 8:00 pm
Wait, let me clarify. Math.sin() will NOT work correctly with an angle in degrees. If you are using radians, you should be FINE.
However, if not:
double angleInDegrees = /*some angle in degrees*/ ;
double sineOfAngle = Math.sin(Math.toRadians(angleInDegrees));
Hope that helps.
