It is currently Fri Feb 27, 2015 9:20 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Sat Apr 25, 2009 5:39 pm
How do you make a text box read only?
PostPosted: Sat Apr 25, 2009 5:45 pm
Million Club - 5 Plus*
What language? There's a ReadOnly property on the Windows Forms textbox with .NET languages.
PostPosted: Sat Apr 25, 2009 5:52 pm
Yep, depends on the language.
Like I've said, it's programming, so there's usually multiple ways of doing things. It all depends on the language, your needs, how creative you are, and how much work you want to do. :)
Off the top of my head:
1) Readonly flag if it is there. Sometimes this lets them type in the box though (it isn't saved, but it might not be what is desired)
2) Enabled flag (it'll still show the text, greyed out, but you can't type anything in it)
3) Keypress type events on the textbox (if any letters or numbers are typed in the box, ignore it)
4) OnExit type events on the textbox (reset value of the box back to the original value)
5) Keypress type events on the form (identify what box has focus, if it is the one in question, ignore the letters/numbers)
And so on. Different ways of doing it, each with their own pros and cons.
PostPosted: Sat Apr 25, 2009 7:21 pm
I assume that because you started on C#, you're referring to .NET controls.
If so...
TextBox tb = new TextBox();
tb.ReadOnly = true;
This is mostly for ASP.NET but the same rules apply for TextBoxes in Windows applications. Good luck!
PostPosted: Sun Apr 26, 2009 7:57 am
for C# my book says to add "&" in front of the letter that you want to make it a shortcut. But when i do that and run it i get an error. Im using visual C# 2008 by the way.
PostPosted: Sun Apr 26, 2009 9:23 am
What do you mean "shortcut"? In C or C++ :
int x = 33;
int* ptrToX = &x;
&x returns the address of x in memory (used here to assign to a pointer).
PostPosted: Mon Apr 27, 2009 6:27 am
I think you're getting ahead of yourself.
When you add a menu in your winforms applications, you can specify a shortcut by adding the & to the text itself ( menuItem.Text = "&File") and that will show up as a shortcut. So when you press ALT+F, it opens up that shortcut.
What exactly are you trying to accomplish and are you following a set curriculum?
