It is currently Sat May 25, 2013 12:25 am
 Post subject: Visual Studio 2008
PostPosted: Wed Apr 15, 2009 8:12 pm
I just installed this on my Vista x64 system. I got it for free off of Microsoft Dreamspark.
It's already on my laptop, the school provided the laptop and programs I need. There is a debugger that is quite annoying that comes up when I view videos or other various things on the web. Is there a way to turn off this "external" debugger?
Any widely known problems with VS08 and Vista x64 or are they bread and butter.
PostPosted: Thu Apr 16, 2009 3:24 am
I know there is a way to turn it off, I think it is called Just in time debugging. I will let you know if I find anything.
VS 2008 is pretty sweet, I won't lie. There was one stumbling block I had when I was trying to connect to an access database (another vendor's application used it for their data... ::shudders::) and I couldn't get it to work. I don't remember exactly how I fixed it but it has something to do with the JET driver not being installed or available under x64.
I was able to fix it and went on my merry way. I just don't remember what that problem was.
PostPosted: Thu Apr 16, 2009 5:13 am
When you install Visual Studio 2008, it also installs debuggers for web development. I believe that you can set Internet Explorer to not trap page errors in the debugger in its preferences.
Go to the Tools menu: Tools-->Internet Options-->Advanced Tab-->Browsing-->Disable Script Debugging.
There are two entries for Disable Script Debugging.
I've been using VS 2008 under both Windows XP x64 and Vista x64. It works best under Vista x64, especially the web application development tools. I noticed a bit of qwerkiness under XP.
PostPosted: Thu Apr 16, 2009 5:58 am
I use Mozilla Firefox, and it came up so many times. I see there is that "Just-In-Time" debugger, and they have 3 options. The last is for scripts. Is it that important or is it just for reviewing websites and such.
PostPosted: Thu Apr 16, 2009 6:41 am
If you're not doing any web development, then just turn off the debeuggers in your browsers. I don't think that Visual Studio messes with Firefox. It sounds like you installed a plug-in of some sort in Firefox.
PostPosted: Thu Apr 16, 2009 7:33 am
It is probably the OS that is letting the JIT Debugger pick up the script error. You can always turn them back on if you need them for web dev.
PostPosted: Mon Apr 27, 2009 12:59 pm
I tried the free version MS is handing out and I'm unimpressed. Too much is going on in the program to understand. I'll stick with my eclipse or BlueJ for now.
PostPosted: Tue Apr 28, 2009 4:08 am
What do you mean too much is going on to understand? I didn't have any difficulty with it. In fact I LOVE some of the features it has!
Can you enlighten me?
