It is currently Fri May 24, 2013 9:10 pm
 Post subject: --Nevermind-- opensource or freeware VisualBasic IDE
PostPosted: Fri Mar 20, 2009 8:08 am
Does anyone know of a good opensource VB IDE? It needs to run on Win 98 (I know it's a piece of junk, but I don't have anything else). Any help would be appreciated!
--fdwhacker
PostPosted: Fri Mar 20, 2009 8:18 am
What version are you running?
What version you CAPABLE of running on Win98?
Most modern IDEs may not be backwards compatible that far.
PostPosted: Fri Mar 20, 2009 2:55 pm
And another thing, are you learning traditional VB (like VB6 type stuff) or VB.NET?
PostPosted: Sun Mar 22, 2009 12:51 am
I don't know if Visual Basic 2008 express edition is compatible on win 98 but give it a try.
http://www.microsoft.com/express/download/default.aspx#webInstall
PostPosted: Sun Mar 22, 2009 9:59 am
I doubt it is, and even if it is, it's not "open source."
If VS 2008 is not compatible with Win98, you might try VS 2005:
http://www.microsoft.com/express/2005/d ... fault.aspx
PostPosted: Sun Mar 22, 2009 11:02 pm
Million Club - 5 Plus*
There's also SharpDevelop and MonoDevelop. Both are OSS. I doubt they're Win 98 compatible though.
If you can't run any of those, try MonoDevelop on Linux.
PostPosted: Fri Mar 27, 2009 7:53 am
I am running Windows 98 First Edition with Service Pack 1. I am using VB.NET. I know that programs created with VB Express 2005 run on 98, but the IDE itself won't.
 Post subject: Never mind
PostPosted: Wed Apr 29, 2009 8:52 am
I'm getting a job this summer to earn money for a new computer, so just ignore this post.
But thanks to all who posted suggestions. It helped me decide what I should use for this new computer.
