It is currently Sun Jan 25, 2015 7:53 am
 Post subject: Java graphics
PostPosted: Fri Mar 13, 2009 9:06 am
Team Member Top 1000
hi, I want to be able to use Graphics to load a bitmap (or PNG) from the hard disk and scale it to 100% of the window, I have read in different places about reading an image off of the disk and then putting that data into an "Image" data type, I didn't quite understand it, can someone explain an easy way to do this?
    public void paint (Graphics g)
        super.paint (g);
        int w = getWidth ();
        int h = getHeight ();
        //drawImage("image.bmp", 0, 0, w, h);
the image will most likely be larger than the window although I'd like it to work when the image is smaller. I am assuming java has built in methods for scaling
