It is currently Fri Jan 30, 2015 2:13 pm
 Post subject: More C++ woes: Custom exceptions
PostPosted: Thu Mar 05, 2009 10:05 am
I'm trying to make a custom exception as per specifications of this programming assignment. I'm still developing using Visual Studio (worked out the kinks of my last question) but I've tried some examples, integrated them into my project, but it gives me this "can't access" violation (I found out it's because the deleter goes nuts). This violation only occurs when I implement the example codes.
So here's my custom exception
class file_parse_exception
   public:
      file_parse_exception(string s) : message(s){}
      ~file_parse_exception() throw(){}
      const char* what() const throw(){return message.c_str();}
   private:
      string message;
And every time I call it, that's when stuff hits the fan. I tried just with the constructor only, but if I throw it, I get an "unhandled exception" error.
Basically I have another class that does stuff, but it has to throw exceptions in the event something bad happens (like accessing an element in an array that's not there)
EDIT: On inspection, VS freaks out when I do the "file not found" exception. So here's my code segment for that:
   ifstream asm_code(file_name.c_str(),ios_base::in);
   if(!asm_code)
      throw(file_parse_exception("Requested file not found."));
      buffer = new char[0];
      lines_code.clear();
The buffer is a char *, I put that there because last I tried doing this, I got an error trying to delete it (this class's dtor deletes the buffer)
PostPosted: Thu Mar 05, 2009 10:55 am
Hate to double post, but I was stupid.
You throw the exception AFTER everything else (that buffer = [0] wasn't being done so that's what caused problem).
PostPosted: Thu Mar 05, 2009 10:56 am
Monkey Fed [PC]
Monkey Fed [PC]
That's not a double post bro. It's good to let us know you found your problem.
