It is currently Tue Apr 21, 2015 6:56 am
 Post subject: algorithm
PostPosted: Sat Feb 28, 2009 10:43 am
hello:
i have this exercise to make it work in visual basic:
make a program in visual basic where the user type 2 numbers that must be show upward and downward using if..else.
my analysis was this:
if num1<=num2 then
listbox.items.add (num1 & " " & num2)
else
listbox.items.add (num2& "" & num1)
this is right?
thank you
PostPosted: Sat Feb 28, 2009 12:51 pm
The problem doesn't make sense to me. What exactly are you supposed to do?
 Post subject: algorithm 2
PostPosted: Sat Feb 28, 2009 1:58 pm
sory i was in an hurry writing the problem, the problem is this:
any user is going to enter in the screen 2 numbers for example: 2 and 3 when the user make an click in the botton RUN the program must display the answer of both numbers in this way: upward and downward
thanks
 Post subject: Re: algorithm 2
PostPosted: Sat Feb 28, 2009 2:28 pm
thanks
Answer? Up and down? Like addition and subtraction? multiplication?
PostPosted: Sat Feb 28, 2009 2:45 pm
I think he means sorted in ascending and descending order.
 Post subject: algorithm 3
PostPosted: Sat Feb 28, 2009 3:39 pm
hello:
Quertior say:
" i think he means sorted in ascending and descending order "
this is what the problem that i need do, sorry but sometimes my writing is bad
PostPosted: Sat Feb 28, 2009 3:53 pm
http://www.google.com/search?q=sorting+numbers+%2B+vb
