It is currently Wed Apr 01, 2015 6:12 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: Best comments found in code EVAR.
PostPosted: Wed Feb 25, 2009 9:28 pm
"What are you doing looking at this?"
PostPosted: Wed Feb 25, 2009 9:29 pm
Monkey Fed [PC]
Monkey Fed [PC]
Did you hit new topic instead of reply??
PostPosted: Wed Feb 25, 2009 9:56 pm
No, I wanted to comment on the "Zombie" thread below. And starting a new topic seemed to be the lesser of 2 evils.
*edIT*
On the older platform, code was sometimes boolean manipulated to scramble it from prying eyes.
So I would run a routine simmilar to this on it.
ldx #$00
start
lda data (start of memory encrypted.)
xor a,x
cmp #$78 (check for "Set interrupt flag.)
beq found
inc x
jmp start
data (encrypted code here.)
found ((end (check x-register for decrypt code.))
(The above might be a bit mixed, but hopefully the idea will come across.)
Exploiting the fact that "proper" coding demanded that the "sei" was always the first line made it easy to view/descramble the old code.
Granted it's been about 25 years since I used this to rev. eng. (Programmers used to leave some nasty messages.)
PostPosted: Thu Feb 26, 2009 5:09 am
This is even worse dude...
That other thread was already resurrected. In that case you should use what is already there....
(Then again, I am of the thought that if there is a thread that exists already you should use that one, old or not. But I don't make the rules :) )
PostPosted: Thu Feb 26, 2009 5:20 am
The other thread has already been resurrected. This was a very stupid thing to do.
